Prevent battery drain camping with gv80
gcm2021
Genesis GV80
Went camping with my daughter in the gv80, worked great until my battery died. I had turned off interior lights, turned off ambient lighting, but opening and closing hatch (plus couldn’t figure out how to turn off the lower door lights) drained the battery. Any tips on how to prevent battery drain when tailgating or camping with the gv80?
I assume the lights were on all night. How many times did you open the rear lid?
yep, that’s exactly what I had to boost my battery with. That’s not my question. It is how to prevent future battery drain. I was able to turn off all interior lights except the ones at the bottom of the tailgate so tried to keep doors shut. But kids opened tailgate quite a few times to get things and without a manual tailgate door latch on the outside, the motorized opening probably drained the battery. Anyway to power down the electronics when camping or tail gating??
Well I just had a read of the owners manual. Looks like opening and closing the lift gate more than 5 times can deplete the battery. The manual also says not to leave the liftgate open and does not recommend manually opening and closing it as it can damage the lift function. So I guess camping or tailgating with the gv80 is a no go. That’s really too bad… downside of fully powered vehicles. Not great for North American recreation. Is there a way to temporarily disable the battery safely?
Start your engine and let it run for 15 minutes or so every day. Or just start it for a few minutes every time you open the hatch.
I know you were looking for a solution, but I was more concerned about the cause. I have monitored my GV80's at rest battery, getting 11.8- 12.3 volts at~70 degrees F. This is below the 12.6 V that is supposedly considered the minimum acceptable voltage. I also tested after opening the liftgate and saw a drain from 12.3 to 11.4 volts. I also bought a portable charger. Because of the complexity of the electronics, I wonder if there is excessive parasitic draw, even at rest, suggesting a system malfunction/defect somewhere within the system. Not very confidence inspiring, to say the least-never had a start problem with other similar vehicles even after multiple tailgate openings.
With a 10mm open end wrench, you can easily, disconnect the negative battery terminal and, if desired, leave the tailgate open all night.
With all due respect, this is bad advise.
Most modern cars don't fully power down when not running. The complexity of their electronics require a constant power supply to maintain the "keep alive memory" which stores the adaptive, learned, and driver set up parameters. Some cars even require a dealer re-set of some systems after the battery is disconnected. Like most the GV80 requires a supplemental power supply be used when changing the battery so nothing is lost. Even when a battery gets too low to start a vehicle it still has enough power to maintain the multitude of computers memories but disconnect it completely for more than a short time and let the modules capacitors go completely dead you are just asking for trouble.
YMMV ...
YMMV ...
Beg to differ. I did this several times with no apparent problems on the 80 and a Porsche 991.1. A couple of quirks appeared but resolved quickly.
thanks for all the great advice everyone! I think I found a solution. I just used the side of a screwdriver and pushed into the latch hook of the tailgate (mimicking a closed door) and that successfully turned off the tailgate lights and turned off the door-open dash warning. I was able to reactivate the tailgate by using the tailgate button on the dash. So think I will do that next time I go camping. And incase there’s power drain from elsewhere, I’ll have my car booster (same one as linked above) and I’m good to go. Happy camper here. Thanks all!
But just remember what you mentioned before. I too have read about opening and closing the hatch will kill the battery. I suggest you just leave it open.
Jhon, I believe even when opened, it continues to draw battery voltage. It is not just during opening.
I have read on Subaru Forums they recommend using a carabiner instead of a screwdriver to "fool" the hatch latch.
