JohnSC
- Aug 16, 2023
- Location
- Greenville, SC
- Genesis Model Year
- 2024
- Genesis GV70 EV
If the model GV70 you purchased has AFLS headlights, you have to set the stalk position to AUTO for them to function. Are you doing that?
If the model you purchased does not have AFLS headlights, then you bought the wrong model for your particular needs, assuming that AFLS is a feature on higher trim models.
There are always aftermarket lighting systems available. Stop by a local store in the mountains and get some estimates. You won’t be the first folks to add extra lighting for special needs.
Here's a link to Genesis Intelligent Front-Lighting System (IFS), which apparently is their version of the "adaptive headlights." It provides side lighting similar to those we had on Lexus and BMW. It's described as optional in the 2024 Electrified GV manual, and the manual does a poor job of explaining it. You have to set it up in the menus, set the stalk to Auto as mentioned above, and then push the stalk forward. A green headlight appears in the dash display.
We've only driven once at night and we didn't have it configured or selected, so no idea how effective this is. But it sounds like what others call adaptive headlights. No mention of it in our Prestige window sticker, but I found it in the menu and used the headlight stalk to select it -- and the green headlight icon illumintated as desribed in the manual.
There is also auto high beam assist, which is selected with Auto on the stalk and dims the headlights with approaching headlights. This was listed as an option on window sticker.
Here's a link to the Genesis "review" of their headlights. You may need to copy the link to a browser, or search for Genesis Intelligent Front-Lighting System.
Genesis’s Cutting-Edge Intelligent Front-Lighting System
