Sue31398
- Feb 5, 2022
- Genesis Model Year
- 2022
- Genesis GV70
I am still waiting on a different part called the liftgate "REAR TRANSVERSE TRIM ASSEMBLY" to come in. Was hoping it would be here by now but will go in tomorrow and follow up on repairs and part delivery. BTW, My GV70 discoloration is noted on window trim on both sides, front and back.Any update from your dealer? I have the same issue and want to know if others are getting it corrected under warranty.
Frank I'm having the exact same problem with my 70 sports prestige trim is getting worse and worse by the day and my vehicle stays in the garage, and never been in any horse weather like snow etc I really even drive it 2022 with 7800 milesI have a 2022 GV70 and a few months ago I noticed a discoloration on the metallic trim around the windows. To me it was more of a patina that would come off when I used my fingernails on it. The dealer service rep said it was a discoloration of the trim that could be removed with a chemical and rubbing. This process took most of the day. The cleaning did some good but some discoloration remains. And the service tech did a messy job which I had to re-clean.
Has anyone else had this problem??
I think the trim is defective and shouldn't discolor or form a patina in a little more than a year.
Yes I have the same issue with mine as well.I have a 2022 GV70 and a few months ago I noticed a discoloration on the metallic trim around the windows. To me it was more of a patina that would come off when I used my fingernails on it. The dealer service rep said it was a discoloration of the trim that could be removed with a chemical and rubbing. This process took most of the day. The cleaning did some good but some discoloration remains. And the service tech did a messy job which I had to re-clean.
Hmm. You would think for a 55k car, Genesis would look at the molding issue. There is a service bulletin where Genesis will either buff the trim or if that doesn’t work, replace the trim. Update on my end, the buffing removed the blemishes but did remove much of the shadow effect on the trim. Against the other parts on the car that have the shadow trim (handles, side slit, grille), the window trim is nearly pure chrome in comparison. Nobody would notice, but I do. Cheap plastic and poor finish. Car and Driver reviewed the gv70 last month and had a pullout blurb on the issue. Dealership told them it comes from the car wash. I have a 2004 Acura that survived PA winters and the chrome is still like new so Genesis’ issue and solve is a real let down.Yes I have the same issue with mine as well.
I wonder if they're going to put the same defective part back on.Definitely a know issue. I started seeing it on my 3.5 Sport Prestige and I mentioned it at my last service. They immediately ordered a new set with no questions and said "I'm surprised they haven't issued a recall notice on this." Apparently, they've done quite a few replacements. My concern is that they are just going to replace it with the same product, which will discolor in time as well.
And this replacement is quite expensive. Definitely do it while under warranty.
2019 g70 have had my window trim replaced 3 times. Has been covered under warranty. They say that the copper color finish has been a big problemTaking my g70 dynamic in tomorrow. They are supposed to buff the discoloration out. I have heard from many that the treatment will remove the blemishes along with the smoke tint, leaving you with true chrome window trim and smoke chrome on everything else. I’ve also heard a few horror stories from folks who have had the trim replaced but done poorly with gaps and misalignment. Any body have experience with either? I’m wondering if it’s best to just have true chrome that lines up vs smoke chrome that may look misaligned and shoddy. I’m also wondering if the reason the driver side, particularity the front fades the most is because that’s where the bulk of washer fluid lands when cleaning the windshield?
Have never had my 2019 in a car wash or used a rag to wash. My trim looked like someone took steel wool over it. The funny thing g it's just the side window trim2019 g70 have had my window trim replaced 3 times. Has been covered under warranty. They say that the copper color finish has been a big problem
weird I have the same problem on my 2024 gv70 sport prestige. It's made in Alabama and I got vin 951. I wouldn't think it was sitting longer then 1-3 months max.I ultimately was able to get Genesis to replace the window trim on my 2022 GV70. They are aware of it being a wide spread issue but no recall involved. I do not think Genesis will do anything to RR the molding on their own. It took Genesis a day and a half to replace the trim on both sides. I am told (BY GENESIS) the culprit is the protective tape or film they apply to the trim during transport from the factory. During the pandemic many vehicles sat outside for long periods of time and as a result the constant UV ray exposure on the protective film ultimately damaged the trim. They also say it can be polished out with rubbing compound but it supposedly returns. Just get it replaced FOC so it does not affect resale.
This was my thinking based on Genesis dealer. Long term UV exposure could of happened during pandemic due to shipping/supply chain delays from ROK. I had to wait a long time to even see any GV70s during 2022 and options were limited. I have no answer if yours was manufactured in Alabama w/o delays.weird I have the same problem on my 2024 gv70 sport prestige. It's made in Alabama and I got vin 951. I wouldn't think it was sitting longer then 1-3 months max.
Yes, what Ulta said. Mine was doing that & I asked about it when it had to go in for recall fuel pump. 2022 GV70. They rubbed it out for me & said it's hard water & to do the 3M compound 36060 on it. And make sure you dry it after a wash. What I find weird is it isn't ALL the trim."
Genesis doesn’t consider that to be a replaceable item under the warranty. They’d sent out a service bulletin to the all or some of the service departments directing them to inform customers to instead purchase some rubbing compound by 3M and use that as directed. I’ve used it and it works perfectly. It’s a tad bit time consuming, but worth it compared to the stains and tarnished look. The product is 3M 36060 Perfect It Ex Rubbing compound."
Dark Chrome Trim Fading and Staining
I'm in the UK and have a GV70 Sport, delivered new in March'22. All of the dark Chrome trims on the doors of my GV70 have faded and are showing stain like marks, which looks terrible. The car is only hand washed using Meguiars Gold Class Car Wash so the staining is not from car wash...genesisowners.com
It does work but a "luxury" SUV should not require this extra arduous maintenance
