rmod
- Jan 8, 2019
- Genesis G70
Just do a couple of more drain and fills yourself and see if that solves / minimizes the issue that you have. Perhaps you can try some other brands like Amsoil, Ravenol or Valvoline for your transmission fluid.I want to keep this car until it actually dies (or requires mechanical work exceeding the value of the car) but I cannot drive a car with a transmission like this for another 77k. It's really disappointing. The manual said not to change the fluid, the dealer said i should have, and clearly i should have. Now i possibly messed something up long term, and the only solution i see here is for someone to take apart the trans and see what's wrong in there. Idk what to do.
This is a procedure for "TCM Relearn" once the adaptive values are reset. Maybe you can try this after a reset.
("APS" below means your accelerator input, "SBW"= Shift By Wire)
