GeeVee7T
- Aug 23, 2023
- Genesis Model Year
- 2024
- Genesis GV70
Hey Team. OK so here's the sitch: 2024 GV70 comes with 21" non-waffle rims, apparently 44lb each (off the web, I didn't weigh them). As we know, 19" rims were previously standard. I put 34lb x 19" aftermarket rims on for winter.
I've tried to understand "rotational mass" / moment of inertia / centrifugal force in Newtons and lbft... and I'll be honest, I still don't really get it. I'm seeing numbers like 17% more centrifugal force to 1:4lb or even 1:10lb for sprung vs. Unsprung weight independent of the diameter of the tire (which affects centrifugal force)... blablblaaaablabla...
OK, so enough nerd-speak - what I get from all that is:
However, in favour of 21" rims we have:
Do I keep my heavy, unused 21" OEM 2024 GV70 non-waffle wheels or try to sell them to subsidize a 19" aftermarket option in the Spring?
More simply put, other than "looks cool," why are so many of us routinely chasing larger diameter rims? I get it - they can look "way gooder..." but is it worth it?
- Lighter is better (unsprung weight)
- Smaller is better (rotational forces)
- "Better" affects: Performance (less force required to rotate/accelerate or slow down), Handling (less force required to turn off-axis and stop, i.e. less steering and brake input required -think "gyroscope"), Traction (less unsprung weight is less effort for suspension to keep wheel on the road), Comfort (less spinning force causing wheel to lift or bounce), Mileage (less unsprung weight and force to rotate - although *once spinning* heavier is better, coincidentally, think: long distance highway runs).
- Price & Availability - 19" rims (235x55-19x8.5) AND rubber can be DRAMATICALLY less expensive and far more prolific in options and availability than 21" (255x40-21x9)
- May look cooler... lol.
