Heads Up display resets on every start up
Shakeydeal
I searched the archives and saw a few posts about this, but no real conclusion on the fix. This started happening after the last software update. The HUD reverts back to the lowest position setting every time I start the car. Anybody have this issue and know what to do?
I don't know if the HUD is included in the driver settings. Worth a try. When you have it set to your liking, do a reset for Driver 1 and see if that sticks.
I tried that already, didn't work.
Yes it does. The brightness kept changing for me once I set it to what I wanted then set Driver 1, it stuck. Hopefully that works for OP.
  • Like
Reactions: JBF
Hmm, it should work..
This is DEFINITELY what you need to do to save the settings, at least in a 2019. They may have changed things with the refresh though (although I don't see why they would).
I will try it again. The whole physical display already needs to be adjusted because at the highest setting I still have to crane my neck to see it. This issue is just another one on top of that.
Ok, so I sat in the driveway, adjusted the HUD and saved it. I started and shut down the car several times and it never moved. This morning I start the car and leave for work, HUD is back at it's lowest position. So that didn't work.
Any other ideas?
