Maintenance schedule
Mpietro
111440mmm
Genesis G90
Hi everyone. I’ve just bought my first Genesis/Hyundai car. It’s a 2017 Genesis G90 with 135K miles. I couldn’t find much information about the maintenance schedule and once I intend to keep the car for a couple of years any tip regarding what might deserve so attention would be appreciated, like transmission fluid change interval, spark plugs or anything else it would be a good idea to check. Thank you.
Sign up and download the manual
What'd you give for it with 135k? I figure around 15-16k?
not bad, considering parts are pretty easy to get, shared with the stinger and some others
Starting on page 422 of the owners manual:
Normal Maintenance Schedule (CONT.)
135,000 miles (216,000 km) or 108 months
❑ Rotate tires
❑ Inspect air cleaner filter
❑ Inspect vacuum hose
❑ Inspect air conditioning refrigerant
❑ Inspect brake hoses and lines
❑ Inspect drive shafts and boots
❑ Inspect exhaust pipe and muffler
❑ Inspect front brake disc/pads, calipers
❑ Inspect propeller shaft
❑ Inspect rear brake disc/pads
❑ Inspect steering gear box, linkage & boots/lower arm ball joint, upper arm ball joint
❑ Inspect suspension mounting bolts
❑ Inspect drive belts (First, 60,000 miles (96,000 km) or 72 months
after that, every 15,000 miles (24,000 km) or 24 months)*4
❑ Replace climate control air filter (for evaporator and blower unit)
❑ Replace engine oil and filter (5.0 GDI) *6
(135,000 miles (216,000 km) or 216 months)
❑ Replace spark plugs (3.3 T-GDI)
❑ Add fuel additives *1 (135,000 miles (216,000 km) or 216 months)
142,500 miles (228,000 km) or 114 months
Rotate tires
(142,500 miles (228,000 km) or 228 months)
❑ Add fuel additives *1 (142,500 miles (228,000 km) or 228 months)
150,000 miles (240,000 km) or 120 months
Rotate tires
❑ Inspect brake fluid
❑ Inspect fuel filter *2
❑ Inspect fuel lines, fuel hoses and connections
❑ Inspect fuel tank air filter *2
❑ Inspect parking brake
❑ Inspect vapor hose and fuel filler cap, fuel tank
❑ Inspect front(AWD)/rear differential oil*3 (150,000 miles (240,000 km) or
192 months)
❑ Replace air cleaner filter
(150,000 miles (240,000 km) or 240 months)
❑ Replace coolant (First, 120,000 miles (192,000 km) or 120 months
after that, every 30,000 miles (48,000 km) or 24 months)
❑ Add fuel additives *1 (150,000 miles (240,000 km) or 240 months)
❑ Rotate tires
Rotate tires
Rotate tires
192 months)
Thank you. 😊
