PatF
- Mar 9, 2018
- Location
- Dallas, TX
- Genesis G90
As I drove my 2018 Genesis G90 to the dealer to address a "check engine" light (I think the correct name is the Master Indicator light), the car began to surge regularly. All warnings began to go off (and sound warning bells. The warnings I remember were BSD (Blindside Detection), shift malfunction, and several others I can't recall as I was driving at the time). As I was about 10 miles from a Hyundai dealer, I headed there. As I pulled into the service line, I got a shift failure warning and the car--by itself--shifted into neutral. I could not move the car even though the engine was running. The speedometer was way off as were most other systems (such as A/C and cabin fan). Several men from the service department tried to push the car, but because it is all-wheel drive, the rear wheels were locked. They had to use a floor jack to raise the rear axle off the ground to move the vehicle out of the way.
I found this experience alarming to say the least.
a. I didn't realize how big a problem the electronic shift mechanism is when it decides to fail. Pulling a car out of drive by itself could lead to many dangerous situations when an electronic problem occurs.
b. One of the many failure warnings involved the automatic braking system. Exactly how this failure would affect control is an issue. I had no problem with the brakes today, but since nearly all electronically controlled devices failed, this issue could be serious.
c. The surging engine concerned me, but at least the engine did not quit; it just ran very poorly.
d. I've never been convinced that the electronic parking brake could ever be use as an emergency brake if the main brakes fail. Perhaps the brakes are failure-proof ;-)
As an engineer, I'm very concerned that any vehicle would allow a single failure to affect so many critical systems. A well designed vehicle should identify problems, but I would prefer some mode of operation which would avoid the dangerous transition of critical systems (such as the transmission) to an ineffective state.
