Tie Rod Ends & Lower Ball Joint
Jacob/Isreal
What are the torque tightening specs for Outer Tie Rod ends & lower ball joints for 2011 Hyundai Genesis 3.8L 4 Door Sedan?
2012 4.6 torques below. Pretty sure all cars are the same for the parts mentioned, but I recommend that you verify the service data for your car.
There are two "lower" ball joints. Tension arm and lateral arm.
Thank you,
I
Thank you, but I've already changed both the front lateral arm & front tension arm about a year ago. I'm clear on those. It's the tie rod end & lower ball joint that I need for a 3.8L. Thank you though.
I couldn't see the attachments before. I see them now thanks.
