2022 G70 2.0
Sshaddix
Curious to see if anyone else has had this issue, my car has 35000 miles currently, as of the last 2 weeks i keep getting the warning on my dash for forward collision assist, blind spot assist and my ABS light. Ive scanned the codes, and they all come back as chassis codes. Collision system malfunction, and wheel speed sensor, i also work at a dealership i had it put up in the air to check the abs sensors and nothing seems to be frayed or torn or disconnected, so im wondering if the issue is the sensor behind the grill? The hard part about this is the warnings will be there one minute and the next they just go away without having done anything. Trying to figure out what this is before i waste time and money for diagnostics at genesis on Wednesday.
You didn't mention which codes the car threw; that'd help. But it could be just a low battery, so I'd start there. Good luck.
I have a 2020 G70 with 36K miles (I barely use it) and it is doing the same thing that you describe. Did you change the battery and go away? If not, how did you fix it? Thanks, Joe
I brought it to the dealer. Turns out it was a bad abs sensor/speed sensor. They have to replace the whole wheel hub when they do it. Should be covered under your warranty
Thank you. Really appreciate it. I think I will be doing the same.
