- Mar 25, 2008
- Location
- Florida
- Genesis Model Year
- 2015
Genesis has unveiled new heated windscreen technology which it says is three times more effective than previous systems.
The next-generation system is designed to improve the thermal efficiency of electric cars and so use less energy. The Korean brand showcased it on its all-electric GV60 and GV70 models. According to Genesis the 48V metal-coated heated glass technology uses 10% less energy than a conventional fan-based air con system and can clear ice three times faster than regular heated screens. In testing on the GV70 and GV60 in temperatures as low as -18°C, the system achieved a completely clear windscreen in just five minutes compared with more than 15 minutes for a regular system.By using a dedicated 48V system to convert energy from the car’s 800-volt electrical system rather than using the auxiliary 12V battery, Genesis says it helps use less energy and helps boost range. The technology works by passing a current through the 20-layer transparent windscreen coating, raising the temperature of the glass consistently and completely clearing the windscreen. As well as quicker de-icing the glass is also better at insulating than other screens. In winter this helps keep the interior warmer using less energy, while in summer it is estimated to block at least 60% of total solar energy, helping to lower cabin temperature by 2-3°C. Read more...
