Crazy electrical issues!
Genegray
Genesis G80
Hey guys, 2015 3.8 sedan here. Could use some advice if anyone has experienced these electrical issues before and can offer some advice.
A couple of months ago, the rear passenger taillight wasn’t working, now it’s working again but the front driver’s side headlight is dim and amber in colour, and the rearview camera only works intermittently and when it does, often it’s a scrambled view (like tuning an old antenna tv).
At first, I thought it was an issue with the wiring harness in the trunk lid, which could still be the case, but when these other electrical issues sprang up, I’m thinking it’s likely something else / bigger.
Curious to hear from other owners, thanks in advance!
Floor harness broken in trunk, and HID bulb failing. You know it is possible to have two separate problems. If you wait long enough before fixing those two, a third, unrelated, one will probably pop up too.
Thank you. You are correct, can you tell me which HID bulb replacement I should look to buy?
Sorry, mine is LED, so I haven't looked into the HIDs used by Genesis. However, I have seen threads on here about HID bulb replacement.
A quick search here for HID gives some promising thread results.
