DBTXG90
- Aug 28, 2024
- Location
- Dallas, TX
- Genesis Model Year
- 2023
- Genesis G90
After just a few days of 2023 G90 ownership:
1) Enable the "off" setting as a default for IGS. It's ridiculous to require me to push the same button every time I get in the vehicle. If I can afford a G90, i can afford to, and likely choose to ignore, any potential 0.1 MPG savings. Alternatively, allow me one or more choices to set a longer default IGS shut-off interval, since I am agreeable to IGS at long traffic lights or in stalled traffic, just not at every single driving pause. This is a G90, not a Prius...
2) Don't always enable "Active" Lane Keeping Assist whenever I initially enable the cruise control, especially when I've already set it to "Warning" in the setup menus. Again, I wind up having to push a steering wheel button every time in order to disable the active assist. Yes, there are times when I'd like to enable active assist, but it's not during the majority of my driving. It should follow the default setting in the menu system. I do understand the that this setting is remembered when re-enabling a previously active cruise control setting (nut it seems to get re-enabled if you push up or down instead of using a center push).
3) Document how many songs can reasonably be stored on a USB flash drive. I loaded up a 128GB USB drive with 4500+ FLAC songs and when I plugged it in, the G90's Infotainment system "went out to lunch" for well over 10 minutes and never fully recovered until I removed the flash drive and restarted the vehicle (twice). Fortunately I was just parked in the driveway! My 2011 Audi A8L handled a 8000+ song count (on two SD cards) just fine, so I'm a little disappointed with G90 Infotainment at the moment.
Cheers - the journey begins...
P.S. No EVS for me. The TX electrical grid is fragile enough as it is.
