EV Battery Life
EdP
Supporting Member
SUSTAINING MEMBER
Parrish, FL
Genesis G80
Saw this today and it may be of interest to the EV folks. My guess is that most don't run them down much anyway
Giving common lithium-ion batteries a break could be key to extending their lifespans, according to a team of South Korean experts.
The researchers have found that prolonged use without a recharge causes degradation. As a result, the group from Pohang University of Science and Technology has a simple tip : "Don't use your battery until it runs out."
So if you regularly use most of the advertised range before recharging, you will degrade the battery more and lose more range than if you don’t regularly use most of the advertised range before recharging. Sounds like the “advertised” range is a scam.
If you can get the range it is not a scam. Over time, however, it may degrade depending on care. OTOH, it is possible to extend the life of the battery by charging more frequent. Home charger? Don't let it go to the end, plug it in. When you need the range, it should be there.
Same with phone batteries. Many say for best overall life, never go below 10% or charge more than 85%.
