Multiple Warning Lights - Check AEB & TMPS. Weak Battery?
skipgen
In the last week or so, I've been getting intermittent dash warnings regarding Check AEB. Sometimes it will come on immediately after I start the car, then go out on the next key cycle. Yesterday, in addition to that, I had the Check TMPS warning show up as well...
My working theory is that now in that in the last couple of months, I've been working a telecommute job & the car hasn't been driven very much - maybe 10 mi a week. Are these possibly signs of a weak/dying battery? Otherwise, the car starts & performs fine.
Thoughts?
Look up "Check PSB" on this forum - not sure if you're experiencing the same issue, but it was an inexpensive fix.
Kinda fail to see how that's related... But I'm all for the inexpensive fix.
Recently faced similar behaviour this winter. First started with Check AEB. Over time more and more lights would pop up. Eventually had Check AEB, ABS, TPMS, AWD, and Power Steering. Power steering was the strangest of all, especially so as it became disabled. Could clear the codes but would come back - sometimes instantly, other times after a few hours or even next day. At one point the issue completely disappeared for a week or so until coming back.
Turned out to be a faulty wheel speed/ABS sensor - rear right side in my case. Replaced it and no more issues.
That was kinda my theory - at the beginning the AEB warning was sporadic. If it was off @ startup, it would reappear after the car started moving...
I'm having this issue too. I was also curious if it's battery-related, because my car has an original battery still. I'm going to start with that, just to see. Car is in this shop right now getting the rear diff replaced, so will have to wait until Friday.
