JB4
Also, reading this thread in its entirety, if I run map 3 should I select that option 7 and change the fuel loop to 70?
I did it seems to have less of that surging we get. Not a full fix but helped a bit.
You can skip it if you don’t feel comfortable but it’s a minus thing.
Thanks. Now I’m getting an error in that the JB4 app won’t download the proper firmware file. I reached out to them for assistance.
Everything up and running. With regards to the surging way more noticeable in Map3 vs Map2 IMO.
Agreed and I think it’s due to the progressive settings they use to get more boost or trick boost sensor 1 and number 2 as that’s where I see a big difference between logs.
I gave up on it as they gave up on it so I just live with it.
Makes sense, when I dropped my car as a test mule with Terry, he tuned it for the settings I run most often which is map 2 in sport mode. Unfortunately the best fuel I have common access to is 91.
