Radio Swap Advice
dloudy
TN
I have the 2010 sedan with the Lexicon system - my nav buttons are up near the screen itself and not in the console. My screen seems to be dead and I have tried to reset everything every way possible, with no luck. Was looking at maybe an aftermarket replacement head unit or whatever, that would mesh well with the existing backup camera and amps, etc. Any suggestions on a nice replacement, other than trying to find the same head unit in a junk yard or on ebay?
Thanks in advance!
Same here! I recently purchased a gently used 2012 Genesis R-Spec with 63k miles with a tech package. I spent a frustrating weekend trying to get an aftermarket Android head unit up and running. Everything worked perfectly except that the temperature control would not change the degrees on the display, the recirculating air would not change on the display and I could not get any sound due to no wake up connection for my amplifier. I finally just packed everything back up reinstalled the OEM radio and nav system and currently seeking an alternative aftermarket system if anyone has any recommendations. Other than that, I love the 429HP while riding in style. 😁
Hello everyone. I have a 2013 genesis sedan with the basic radio. I would like to upgrade it so that I have a rear backup camera, touchscreen, and most all other features that come standard nowadays. Anyone with a 2013 do an upgrade and have a recommendation?
We have a 2010 with the basic radio, not the navigation unit. Our state has a hands-free phone statute, but the Hyundai Bluetooth function quit in 2014. I installed the cheapest generic Android that I could find on the Amazon River. If we buy something from the world's longest river, we can always return it to the jungle. The radio antenna converter was a mismatch, so I spent $20 extra for a splitter, a Fakra, and a HFC converter to enable the OEM antennas. I had invested many hours of how-to videos and read everything I could find on Google before I bought the bottom of the line unit. My goal was a backup camera and a hands-free phone, not state of the art performance. If our children are not content with this head Unit, they can always buy a better one. Most of these units, regardless of price, use an MTK-8227L microprocessor that can only address up to 2GB of RAM. Vendors can refuse to acknowledge and answer technical questions, and buyers may not know what questions to ask. Therefore, we bought the cheapest one with an old hardware design.
Installation required using multiple plastic levers and a #2 Philips screwdriver. The OEM CD changer will no longer work, so eject your favorite disks before you disconnect the battery. The online videos do not provide all the information required to remove the bezels. Look for two screws under the instrument panel bezel. The knee level bezels must be lowered first, but not completed removed, to reveal the two hidden screws.
We retained the CD player face plate, so it still looks original.
So far, it does what it claims to do. We immediately linked our phones to the HU, programmed the navigation to our neighborhood, and set our favorite radio stations. Everything appears to work as intended. If you can't install a car radio yourself, a local technician should be able to install it for a couple hundred dollars.
Which radio did you purchase?
This is the one that we bought, but it was not a panacea. As I suggested, this is not a quick DIY project. Plan your project well in advance.
It is totally compatible for our Genesis Sedan. The package included:
1 x Car MP5 Player
2 different styles of Power Cable
A GPS (windshield corner) Antenna
An extra-long Rear Camera Cable
1 RCA i/o Cable
2 USB Cable
1 Rear Camera
1 External (A pillar) Microphone
1 x VERY Important Control Area Network (CanBus) Box
Instruction manual, of questionable value
System: Android 13 Chipset: 8227L-DEMO
Screen size: 9in Memory: 2GB (RAM)+32GB (ROM)
Screen resolution: 1280x720 Radio chip: MT6625
Power output: 4x45W Work temperature: -20℃-75℃
Steering wheel controls interface
Power amplifier chip: TDA7388
Radio band: FM RDS
Video output support
Reversing input: CVBS
External microphone support
Split screen support
Maps: built-in offline maps (requires internet to download data)
WIFI support
USB: Double USB interface
Audio format: APE/FLAC/WAV/MP3/WMA
Video format: MKV/RMVB/AVI/MP4/MDV
Picture format: PNG/JPEG/JPG/GIF/WBMP/BNP
Factory setting keyword: 8888 or 3368
Even though we replaced the radio, our kids objected to the additional vibrations that the 15-year-old speakers generated. We discovered that the glue that secured the voice coils to the plastic cones had separated which disconnected the two primary speaker components. This created an annoying buzz to most of the speakers. We first tried adding more gel super glue without removing the door speakers. Gravity forced the glue down the cone, so the repair did not work for long. The next speaker was removed by drilling out the rivets, placed horizontally and reglued with much better results. We used Rivet nuts and bolts to replace the drilled out fasteners. This was acceptable to the drivers that did not demand loud music, but the obvious solution to old speakers is to replace them with new ones. We bought Pioneer 5 1/4 door speakers to replace the offensive old Hyundai speakers. We also advised the children to turn the volume down.
