Genesis 2013 Instrument Cluster problem
OPUS
My Genesis 2013 sedan V6 4 Dr. Instrument Cluster stop working no Speedometer, Tachometer, Gas & Temperature indicators.
Can some one help with this? the Part number: for the Instrument Cluster is 94016-3M561
Are you sure there isn't an "input" issue?
Hi Jep604:
What do you mean there isn't an "input" issue?
Hi Jep604:
The cluster gets its power thru a pink/red 10A fuse. If you open the driver's door all of the way, the fuse panel access and the Cluster fuse is on the upper row, second from the right. It might be bad. Might be a much less repair.
Hi Jep604:
I checked all the fuses related to the Instrument Cluster on the Driver's side also ont the Passanger side. My mechanic use a Diagnostics Tool "THINKTOOL" and it got a code B1562 (Fuel sender ERR) he by pass the Fuel sender and Fuel Level Sender and still gets the same error. So we concluder there is a problem with the Instrument Cluster or the MCU
Hi Jep604:
Understood. There should be a few very intelligent people piping in soon with some wisdom.
Thank you Jep604...
Fix problem, by installing a redonditioned Instrument Cludter.
Buit I still have to fix the high millage from this new unit.
Great news.
