battery paranoia caused me to do some testing.....
DaveP65
Genesis GV80
Hello - I've owned a 2023 GV80 for about 10 months. A few days ago I noticed on this forum that many were having battery issues. I haven't yet, but I was curious. I went to the Genesis Owner's site and selected "Connected Services" then "view all". The screen showed a 77% charge. I'd taken a few longer trips lately and I thought this was too low, so I bought a CTEK charger. I ran the CTEK charger in AGM mode overnight and in the morning it was up to the 7th light, which indicated a full charge. I went back to the Owner's site and checked again - This time the Genesis Owner's site said 81%. So CTEK says battery is fully charged, Genesis site says 81%....so I bought a battery tester.
The tester arrived today. The first thing I have to enter in the tester is the type of battery - I know it is an AGM - but the tester is asking for either
AGM flat plate
AGM spiral
Does anyone know which type of AGM is in our GV80s?
thank you
Dave
Good work so far. I thoroughly commend you!
I suggest you pull (if you need to) the battery to look who the manufacturer is. Then either go to their web page or customer service phone # and ask.
I'm not brave enough to remove the battery, but I did remove the panel in the back of the car to get that picture.
I also found this link on CARiD - which has the same part number that is on the top of the battery - could it be that Genesis / Hyundai is making their own batteries?
I've also checked several manufacturer's sites and not a single one has a replacment GV80 battery.
Dave
Pretty sure it is flat plate.
The battery is a flat plate type. Spiral or cylindrical type, like the Optima brand pictured below, have a case design that shows the cylindrical cells.
(FYI, the CTEK MXS-5.0 review at the link below has some info on using the AGM mode. After doing some research last year on the batteries used in Genesis models, I decided to stick with the lower charge rate for standard flooded type batteries).
Tau,
Thanks for your comments and for the link to the review.
Does this mean you're not selecting the AGM mode ?
Dave
Odds are it's a flat top but you never know.
AGM flat plate
AGM spiral
thank you
Dave
If it makes you feel any better, Mine had never registered over 77% for the 16 months I have owned mine. It is usually mid 60'a to mid 70"s. It has sat for over a week on many occasions and I have never had a problem with it.
FYI--The OEM battery manufacturer is Sebang Global Battery, a Korean company that sells in many countries (including the USA) under the product name Rocket Batteries. They offer a retail version with the exact Genesis power specs (Rocket 49AGMX) for less than $150, HOWEVER it is NOT an "R" spec battery, ie, like most others in this Group Size 49, the terminal locations are opposite what the GV80 is looking for. Nevertheless, for price(!) and availability, I bought and installed this battery with the terminals facing toward the REAR of the car, since the dimensions and charging specs were/are identical to the OEM (as it IS the OEM battery). BUT, I had to do about 2 hours of mods to the cable arrangement and especially the hold down bracket (trimmed with bolt cutters and a grinder), and add additional insulation around the terminal bolts. Parts, etc. were about $25 additional. Saved a few hundred dollars and now can substitute any "normal" Group 49 off the shelf AGM battery in the future. The mfg/dealer told me that their OEM arrangement with Genesis says they cannot sell the "R" terminal battery with the "proper" terminal locations for another 5 years (ostensibly so Genesis can continue to capture monopoly rents in the meantime). Caveat Emptor!
Also, from elsewhere in this Forum, another poster tagged a Korean video on the charging system.
I am reposting it here for the benefit of users (forgive the missing credit attribution as I could not refind the original post--if someone else knows it, please tag this post with the proper attribution to the original OP--thanks):
Edit: I did find the OP, DuckMan7===Thank you!
Here is his original post link:
*****This video is in Korean, so I will briefly explain what they are saying in this video.
1) Smart generator control system
When the battery's SOC (state of charge) reaches 84% (~12.65V), the car stops charging and let the battery discharge to 12.5V (~70%).
Then the cycle repeats.
(Nominal alternator charging voltage is 14.3V, this should not be confused with resting voltage that SOC refers to.)
The battery is not charged when accelerating to save on gas and also not to burden the engine, and charged when decelerating.
2) ISG (Idling Stop and Go) system has integrated regenerative braking system.
ISG system is designed to save gas when you briefly stop at a light by stopping the engine and restart when you put your foot off the brake.
This obviously takes some juice from the battery each and every time.
To help with this, the ISG system integrates regenerative braking system.
Regenerative braking is a common feature for a hybrid or all-electric system, but I'm surprised to find out all-gasoline vehicles with ISG also have a version of regenerative braking system albeit probably much smaller in capacity.
Nevertheless, this gives me some peace of mind when using ISG that every time I slow down, the AGM battery is receiving some boosted charge from the brakes (as opposed to relaying on alternator and gas only) and use that harvested energy to help start the engine the next time.
3) They recommend their AGM batteries to be maintained with minimum of 12.60V (~76%).
What this tells me is that after driving the vehicle for a while, we should see battery level anywhere between 70% to 84%, provided you drove long enough to allow for sufficient time to charge/discharge.
Then the question is, why max 84% only and not 100%.
All other sources I've managed to find on the internet says the lead-acid batteries are best kept at full charge.
If left at a lower level for a long time, the sulfation crystals harden and the battery can no longer be charged beyond that level.
I suspect the reason the car is only designed to charge up to 84% is because that's the max level the bulk charging process can achieve.
To receive the remaining 16%, the battery must be kept in absorption charge phase and that takes relatively long time to receive the remaining 16%.
During the absorption charge phase, if there is a stop and go event, the amount of charge the battery lost cannot be recovered quickly because the battery cannot be charged quickly with high current like in the bulk charge phase.
Although this manufacturer does not say in the video (for obvious reasons), I think it is still a good idea to charge the battery to 100% using an external charger like once a month or as often as you can if you intend to keep the battery for a long time like 6+ years according to several owners who did just that.
Thanks for the info.
I have had mine for 4 years now and my battery has never gotten above the mid to upper 70's dropping into the 60's at times.
Last month I took a month long Vacation and left it on a trickle charger while I was away. For the first time my car got into the 80's when I checked it when I got home. (88 to be exact)
Two weeks later it is back into the 70's. But, I don't drive much so with what you posted, that makes sense.
I was thinking of replacing my battery just in case. I even had the dealer test it earlier this year. They charged it up to test it and they said it was in great shape. But I was still worried. After reading what you have posted here, makes me trust that the battery is ok and being in the 70's where it should be for me.
Thanks
