dzgooner
- Oct 13, 2025
- Genesis Model Year
- 2015
I changed the fluid once and skipped the 120-140F level setting part. Car started slipping gears.
I did jack the car when cold, did add 0.4L until it was dripping from fill plug (just to prevent destroying the transmission until i have access to a lift), and surprisingly the car was shifting smoothly.
Things were weird when I followed the official procedure, lift the car level, shit gears until 120F and add fluid 0.6L until drips from level plug, now it's slipping gears even worse than before.
Question is, does this make any sense? I mean can transmission shifts bad on a correct fluid level and it will adjust or should i remove the 0.6L as i'm overfilled now? pretty confused here...
