Brembo Blake Bleed Sequence
bnmlambert
I will be flushing my brake fluid soon and read that there is a different sequence for Brembo brakes compared to standard. The sequence was not listed for Brembo brakes, maybe in the link in the post which is now not accessible. Any help would be greatly appreciated.
2022 G70 AWD 3.3 Sport Prestige
Everything I have seen is normal. RR, LR, RF, LF, Bleed the inner side and then the outer, then move to the next wheel. That is how I would have done it. Hopefully it is that simple for you.
The correct sequence for Brembo brakes is to bleed the caliper with the most brake lines first. Start with the front left, then front right, followed by the rear right, and finish with the rear left.
Most brake lines? My G70’s Brembo brakes are 1 line each (2 bleeders per front caliper as I recall). I follow the standard of farthest caliper from master cylinder first, so RR/RL/FR/FL.
You're doing it right. The two bleeders are just for a large caliper. Treat each one as a single line.
Your order is correct: start at the rear passenger side, then rear driver, then front passenger, and finish at the front driver side. That's the standard method.
Here's the factory service manual pages for the brake bleeding, for floating and Brembo calipers.
We've done both the conventional way (farthest from MC first) and the factory service manual stayed sequence. Both work just fine and couldn't tell any difference.
Realistically, its more important you bleed out all the old fluid and any entrained air bubbles. New brake fluid is cheap, use a little more just to be sure.
In searching before posting, I would have messaged you directly as you had answers in other brake posts. I could not find the option to private message or direct message you. thanks!
