No sound
oldbenz1
Michigan
Genesis GV80
My 2023 GV80 is acting up again. Now the radio is not working. Display shows the selected station and reacts to station changes, but there is no sound. It's as if there is a mute button that has accidently been pushed. Wife says this happened to her in the past, but self-corrected after time.
The rotating volume control on the steering wheel should be the Mute button when pushed IN once. Push IN again to unmute.
Thanks for the reply, but I had tried that with no luck. As it turns out, somehow the rotating volume control had been accidently rolled down to where it was at the zero sound position- fortunately a happy fix!
Well, okay then. I suppose I thought that was the obvious first thing you must have checked, but whatever. Glad you got it worked out.
