I need help - blown engine!
Wis
Genesis G80 Sport
Hi. I have a 2019 G80 3.3 twin turbo with 103,600 miles. Dealer said the engine block is damaged and the entire motor needs to be completely replaced for $20,000.
I was told that oil was leaking (undetectable by me) causing the damaged block. Because there is no way to prove it was not an error on the last oil change (over tightening the filter), there is no way Genesis would possibly make an exception with the 100k warranty.
Any thoughts, recommendations, etc, please?
I spoke to an auto appraiser who pretty much said to steer clear of the brand. Something about Hyundai being known for have engine issues.
I love my Genesis!
Thank you.
I love my Genesis!
Thank you.
Hyundai did have an engine problem, but it was NOT a Genesis engine.
I see a couple of options, all expensive. Replace the engine. Assuming the rest of the car is in good shape, it should last you another 100k miles or more. Given the overall age and miles, along the way expect normal wear to pop up.
In spite of the engine, there is some value if you can find the right buyer. There are people that would replace it with a junk yard engine and make some money when they sell it. You won't get much for it. Talk to a couple of local shops, you may be able to do the same for a lot less money. It will be a used engine, so some risk on wear.
What is the value of the car with a new engine? Looking at some numbers, it is close to breakeven. Maybe walking away and getting something new would be just as fiscally prudent. Check the range of values here for starters
Thank you for your thoughtful reply. It is much appreciated. After speaking with an auto appraiser and a very highly rated mechanic, I am getting rid of the car and never touching a Hyundai/Genesis product again.
As much as I love my G80, the mechanic who be earning approx 3-4K on labor gave me the recommendation to not fix the car and move towards a more reliable brand. Painful for me, but I am moving to Lexus.
Thank you again.
Thank you again.
You're welcome. Getting rid of it is a good decision.
