G70 won't start
rich109
Hello all - this has happened twice now. I go to start the car and everything lights up like its starting but nothing happens. It's not the battery. I tried using remote start and that didn't work either - just said that remote start failed and to check that the doors were closed, etc. When it happened abaout 6 months ago AAA came and could not get it started. A couple of hours later when tow truck came it started right up. It happened again the other day and after 2 days of no luck it started finally. I did remote start again and sat outside while it tried to start. I could hear something, and could look into the window and see the dash light up. After a few attempts in the cycle it started up finallly. Has anyone ever run into this?
Just had this happen to me twice this week. No idea what or why this happens but both times I noticed the brake pedal felt very stiff. When I pressed down hard on the brake pedal it fired up immediately.
I'm going to contact the dealership next week hopefully someone has a definitive answer.
Stiff brake pedal is usually a vacuum leak. I had it happen for about a week after an overnight stop and then was OK. I'm guessing a bit of dirt got into the check valve and finally cleared.
To clarify, the leak is in the vacuum tank system for the power brake assist.
Brake pedal pressure is required for start sequence. Someone here long ago said this problem was overcome by pressing extra hard on pedal. That allowed start sequence though reason for resistance was still unsolved. Best of luck.
