I need help with my transmission
Tawiah_jnr
Genesis G80
friend borrowed my car, called me later saying the car doesn’t drive when it’s put on D and tries to move and that the car only goes into reverse. Mechanic checked and says the transmission valve body needs to be replaced. Can anyone help with getting that particular part. Been searching but haven’t had any success
Did he try anything crazy, like throwing it into "R" (for "Race") at 70 mph?
Year, model, mileage? Was the transmission fluid ever changed?
He’s been sketchy with the details, mechanic says the transmission fluid is intact, but it’s the solenoids on the valve body that’s been damaged. Don’t know if I’m getting the technical terms right but that’s the info I have now
It’s a 2015 Genesis G80, KMHGN4JE5FU015141 that’s the vin
Okay, so it's a 2015 Hyundai Genesis. The G80 branding started in 2017.
No one can diagnose this over the internet. It sounds like you friend did something bad to the car. But who knows. Take it to a transmission shop and see what they recommend. Good luck.
Do not lose hope this same exact situation happened to me Same exact scenario 😅 I should have never borrowed my vehicle to someone else You have to take caution with these so called Transmission Shops unless you really trust them Most don't understand the Genesis G80 8 Speed AT functionality very well Technically you need an advanced professional scan tool that can read "Automatic Transmission live data" in the AT Menu to show you the actual active parameters of each active solenoid when the vehicle is on and you running through the gear shifting in order to determine which solenoid is dysfunctional In my particular case I found out that it was Torque Converter Solenoid ALSO Check the wire harness connector and cabling from AT to the TCM
It’s been months now beeen trying to get a replacement can’t seem to find one. Found out my model was discontinued early making the parts very scarce. I live in Ghana. Do you by chance know how I can get a full transmission gear box that’s the recommendation now
Buy the solenoids from Korea. You can buy them online through sparekorea.com and have them shipped to you.
Ok will try that, my mechanic said it’s 50 50 and may not work. Can just the solenoids be changed on the valve body
