Noise when decelerating
draco24433
Puerto Rico
I have an 2010 that every time I decelerate, I hear a "fluttering sound" coming from what seems to be the front right side of the car. It is more pronounced during the morning time but not limited to it. Has anyone experienced this? I cant quite pinpoint the problem but it is driving me crazy. Any help would be greatly appreciated.
Thanks
Have you had the TSB done on the prop shaft? Others have described a shuddering or vibrating sensation attributed to the prop shaft being slightly out of alignment, which this TSB is supposed to remedy.
that could be come from the parking brake that is not completely released. Especially when it is cold in the morning. When I hear that in the morning ( first few hundred yards ), I will stop the car, apply the parking brake and release it real quick. Then the noise would be gone. There was a recall for the parking brake before. But I never went to the dealer for the recall, because I wonder their capability to put everything back right. I guess that might be the root of the noise.
Thanks. That same noise and vibration is being felt right underneath the center console.
Try to determine if the sound is from exhaust. Try placing the car in neutral and coasting. That will relieve back pressure a bit. Then carefully try coasting down with engine off in neutral - be careful though to do this on a deserted road as you will lose power steering and some power braking with motor off.
If the sound disappear, the source may be in the exhaust system.
I think this is a warranty issue. It could be a loose core in one of your cats.
Thanks
See this thread...
http://www.genesisowners.com/hyundai-genesis-forum/showthread.php?t=5462
The answer is there.
the fix is very easy.
QCTLG,
Thanks much. I took it to the dealer but like always the could not duplicate the problem even though it is getting progressively worse. Sometimes it feels as if the shaft will just fall off the vehicle. Service here in PR is unfortunately horrible. I have been waiting three weeks to get my steering column fixed.
