YEH
Here's Cars.com's comparison of the 5.0 to the 3.8.
http://www.cars.com/hyundai/genesis/2012/expert-reviews/
While there have been a couple of reviews which have found the 5.0's ride not quite as sedate as the 3.8/4.6's, there have also been a couple of reviews which preferred the suspension setting of the 5.0 over the non-R-spec trims.
Seems like more time test-driving is in order for potential buyers.
Typically when an automaker goes through the trouble of coming up with a performance name like "R-Spec," the car itself is aggressively tuned, the ride quality suffers, and comfort is sacrificed for pure performance. One look at the 19-inch wheels wrapped in run-flat tires, and I thought I was in for a rough ride.
The second I turned out of the parking lot, the Genesis felt … sedate, like I was riding in a posh luxury car such as a Lexus LS 460 or even a Mercedes S-Class. Indeed, the R-Spec is much more of a grand tourer than a sports sedan.
The power comes on in a silky-smooth delivery, no doubt enhanced by the new eight-speed automatic transmission. There is no severe revving to launch you from the line. That smoothness matched to the eerie Lexus-quiet cabin and pillowy ride makes the R-Spec deceiving. It doesn't seem like you've gotten to 60 mph in just over 5 seconds, but you're there faster than you thought, and by your second thought, you're at 80 mph.
If I had to travel hundreds of miles in a straight line, the R-Spec would be a great choice. Even on twisty roads through the Nevada desert, the R-Spec handled well with lots of grip, but it was a bit hard to judge your speed going into corners, which made some sweeps a bit wider than I wanted.
Then I stepped into the Genesis 3.8. Aside from the wheels, the cars look nearly identical inside and out, but there is a world of difference from the driver's seat.
The difference in power isn't the most significant drop in driving pleasure. Whereas the R-Spec was deathly silent, the V-6's smaller wheels and tires led to much more noise and vibration. If I had taken the V-6 out first, it probably wouldn't have distracted me much, but the difference was stark.
The suspension was also less tuned in. Over road undulations, the 3.8 had a floatier ride.
Traveling at 70 mph and higher on the highway was still a pleasant affair. Unless you crave power, the V-6 has enough — more than most cars in this segment, in fact.
But my co-pilot and I both preferred the R-Spec. To the tune of an additional $12,300? I'm not so sure.
