Edit Phonebook Entry
studyaid
Boca Raton, FL
I tried searching for this, and can't find anything, so I decided to ask. I have the '09 sedan, and got my software updated a while ago. Well, I just got a new phone and I was pairing it with the car, and it worked fine. I was even able to sync my phone book with the phone book in the car. However, I wanted to edit some of the names to what I am used to using when I use the voice commands.
When I go into edit for the respective entry, I am able to edit the name, number, and what the default number should be. But, there is no way to save the edit. I can't go back to the main phone screen, and if I try to go to a different screen, such as XM, or map, it doesn't save the changes. Does anybody know what I'm doing wrong?
If it's tech optioned with a DIS system the "Back" button is sort of like an enter button in this respect that action saves the entry and takes you back one step.
I didn't know we could sync the phone numbers in the 09 model. Is yours the Tech package?
i had a 2011 3.3 chinese version, and original phone book could sync phone book with my Iphone4, but after update nav map I lost this function. After connected with IP4 using bluetooth, it present gray:confused:
The back button is greyed out. I can only go up or down, or edit. It will not let me go back to save. I can not use a voice command either.
It's not on-screen "Back " button but the DIS controller physical "Back" button.
I found the back button, it is above the DIS wheel. I'm sure I used it before, and just forgot about it, since it's not something that I use every day. Anyway, that worked, all is fine with the world now. :)
