A list of recommendations
Easy:
1. Buy this: http://www.amazon.com/Seagate-FreeAgent-Ultra-Portable-External-STAA320100/dp/B003ELOSEG/ref=sr_1_2?s=electronics&ie=UTF8&qid=1322328528&sr=1-2
2. Format HDD to Fat32 using this utility: http://www.softpedia.com/get/System/Hard-Disk-Utils/Fat32Formatter.shtml
3. Copy up to 250GB worth of mp3's onto portable HDD.
2. Hook up via USB in center console.
4. Enjoy!
Good idea, would just like to see it built in vs. external....does doing it this way give you on screen access to the songs so you can see what's playing or just forward/reverse of track?
Their is also a voice command to turn off the center display...goes something like "Full display Off" something like that ;-)
That doesn't turn off the one btw the speedo and tach though.
Sent from my SGS2 using Tapatalk.
Pretty sure that if you format it right, you can see it under the "FOLDER" option. Can someone verify?
Put the new 10 speed in the R Spec - STAT
Paddle shifters
Rev Matching downshifts
Another 100 horsepower
A better Traction control / stability control system
In addition to everything already mentioned,
- There should be 8 preset buttons on the dash - 1 press for 1- 8 and two presses for 9-16
- better shading on the display as it very hard to see in the daylight sun
Regarding your av display (Display - RDS info for FM/XM on the center display:) just push in and hold the radio on/off volume control located on the CD unit (below center controls) to turn off display.
