The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Genesis parts & accessories
Advertise with us!
Advertise with us!
This seems like the place to ask this, i've posted on a couple different sites, i'm looking for opinions on Hyundai transmissions. is it better to do a flush or a drain and fill? any benefits or risks to either. any feedback is appreciated.
The 2009-2011 Genesis Sedan transmissions (ZF on 4.6, or Aisin on 3.8) both use synthetic transmission fluid (but different synthetic fluid specs) and are not designed for frequent or easy changing of the fluid. So I would say that, considering that they make if hard to change the fluid, and thereby discourage non-professionals from changing it, I would say there is risk of you doing either a drain or flush. These transmissions have a 10 year - 100K mile warranty (for original owner), and do not need to be serviced in that interval. I know that may be hard to believe, but have you ever owned a car that came factory fill with synthetic transmission fluid and had no transmission dipstick?This seems like the place to ask this, i've posted on a couple different sites, i'm looking for opinions on Hyundai transmissions. is it better to do a flush or a drain and fill? any benefits or risks to either. any feedback is appreciated.
The difference between engine/throttle/injector/ECU technology between 1986 and 2012 is probably greater than the differences between the Model T and your 1986 IROC Z28. Things change.I have not used a fuel system "cleaner" in the coupe yet (only 8500 miles or so on it now).
When I got my 86 IROC Z28 it would start up, idle a little bit and shut off. The guy I bought it from said he's been told to have the fuel injectors "professionally cleaned" to correct that issue - it had 124,000 miles on it. I drove it home (2 hour drive) and the next day and for the next 3 or 4 tanks of gas I put a bottle of fuel injector cleaner in it. After the second or third bottle it stopped shutting off and the only time I've had that issue since is when I tried to run some Mobil premium gas through it. After the second fill up the engine would shut off just about anytime I let up on the gas pedal. Changing brand of gas and running a couple of bottles of fuel injector cleaner through it would once again eliminate the problem.
These days I run a bottle of fuel injector cleaner through all my vehicles about once a year.
If you really want to have it done, purchase a bottle of Chevron Techron from any auto-parts or discount store and follow the directions on the bottle. That is what your dealer would do for the $189.
Why are we suggesting using fuel system cleaner then? The mobil gas that gummed up my IROC was made just 3 or 4 years ago. After two separate experiences (the second to confirm it was mobil gas causing the issue) and finding the fuel injector system cleaner took care of the problem I can suggest fuel injector/fuel system cleaner as a possible "fix".
Today's gasoline may be cleaner that it was 20 or 30 years ago but it still leaves a certain amount of deposits in areas of the fuel system over time. Every liquid carries materials of some type(s) in it that settle out somewhere when flow slows/stops. Otherwise why would we need filters?
My old IROC does pretty good. Last time I had it on the highway at my speed I got 23 mpg and at the posted speed limit I got 27 mpg. In town I regularly got 20 to 21 mpg (the way I drive). Even the 305 TPI engines had more torque than the V6 engines in the Genesis and with the same weight the feel coming off the stoplight is that same until well after the posted speed limit. I kept my IROC because it runs and handles pretty good. How long will most folks here keep their Hyundais?
I always enjoy riding the folks with the mercedes, bmw's, etc. They sure pay a lot of money to ride around in something they won't run off and leave the old IROC in. Been there/done that too many times. However, I've reached the age were driving at or above twice the speed limit on the interstate isn't the thrill it used to be. Getting old sucks.
Arguing about whether or not new technology is better than old technology is like arguing about the 9mm vs. .45 acp, or the Glock vs. the 1911 or the M16 vs. the M14. As they used to say years ago when I still read gun magazines - that's a discussion that generates more heat than light.
I don't have any objection to using fuel system cleaner, especially once in a while, but the issues with your IROC are not with the gas, but partially with the 1986 engine, and partially that the gas made today is not designed to work well in an 26 year old engine.Why are we suggesting using fuel system cleaner then? The mobil gas that gummed up my IROC was made just 3 or 4 years ago. After two separate experiences (the second to confirm it was mobil gas causing the issue) and finding the fuel injector system cleaner took care of the problem I can suggest fuel injector/fuel system cleaner as a possible "fix".
I never said today's gas is cleaner. I was talking about engine technology differences, and also (as mentioned above) that gas today is not designed to work well in a 26 year old engine.Today's gasoline may be cleaner that it was 20 or 30 years ago but it still leaves a certain amount of deposits in areas of the fuel system over time. Every liquid carries materials of some type(s) in it that settle out somewhere when flow slows/stops. Otherwise why would we need filters?
I am not going to get into any argument about older vs newer engine technology. Today's engines are cleaner (air pollution), get better gas mileage, and have more horsepower, require much less scheduled maintenance, and are much more reliable. Back in 1986 there was a big difference between engine manufacturers in terms of reliability, but those differences are much fewer today. There are very few cars today that fail to start the first time, every time, the ignition is turned on, even when the car gets older. But in the final analysis, it not just modern engine technology being better or worse, but being different than in 1986. The primary reason for this are improvements in computers used in the engine itself, and improvements in computers to design and manufacturer engines, and also outsourcing and sharing of technology among many manufacturers.My old IROC does pretty good. Last time I had it on the highway at my speed I got 23 mpg and at the posted speed limit I got 27 mpg. In town I regularly got 20 to 21 mpg (the way I drive). Even the 305 TPI engines had more torque than the V6 engines in the Genesis and with the same weight the feel coming off the stoplight is that same until well after the posted speed limit. I kept my IROC because it runs and handles pretty good. How long will most folks here keep their Hyundais?
