Micro USB drive used for music
homeofstone
Athens, Georgia, USA
Here is link to what I am using. Its very small and does not get in the way in console compartment. Its less likely to get damaged or to get bumped and damage the usb port. [ame="http://www.amazon.com/SanDisk-Cruzer-Fit-Flash-Drive/dp/B005FYNSZA/ref=sr_1_1?ie=UTF8&qid=1343280964&sr=8-1&keywords=micro+flash+drive"]http://www.amazon.com/SanDisk-Cruzer-Fit-Flash-Drive/dp/B005FYNSZA/ref=sr_1_1?ie=UTF8&qid=1343280964&sr=8-1&keywords=micro+flash+drive[/ame]
Pretty sweet. I'm using a 16G Sandisk and it's huge compared to this one and I paid probably $30, but this was when I bought the Genesis 3.5 years ago.
Here is link to what I am using. Its very small and does not get in the way in console compartment. Its less likely to get damaged or to get bumped and damage the usb port. http://www.amazon.com/SanDisk-Cruzer-Fit-Flash-Drive/dp/B005FYNSZA/ref=sr_1_1?ie=UTF8&qid=1343280964&sr=8-1&keywords=micro+flash+drive
I just bought this for the exact same reason. I have over 2000 songs on it and about 6 movies. Be careful how you format it. The genesis isnt the best at searching sub-folders.
OneFun
Yea, that's the only size I use now..have several..only drawback is that once you push it down into the USB port, it can be difficult to retrieve due to the port's proximity to the console walls
^^ This. Plus, I often forget where I leave them and end up losing them...they are hard to see in certain places haha
Yea they are so small...easy to misplace..I keep a ziplock bag around to put them in when not in use.
A simple and versatile answer to this is to buy a 6" or longer USB extension [male to female]...for pennies [try "Meritline" or similar].
Now any size USB can be connected without contortions!
Or Monoprice.com - love that freaking site!
+10. I figured that one out not too soon after I started using those tiny USB memory things.
It really defeats the purpose of having a slim USB flash drive though LOL
Mine's great. I use the center console every single day, and the USB is completely out of the way, and I don't worry about damaging it!
The manual states that leaving the USB drive inserted when turning the car on/off could damage it. Has this ever happened to any of you?
Nope... been using mine religiously for about 4 months. Use it every day.
I don't see how or why this could happen...Unless there's the possibility of a power surge to the USB port upon starting the car. If the car is off, then nothing is happening with the USB port or the USB drive.
No, but I have a duplicate usb in case the one in the car crashes.
I couldn't care less if it should damage the USB key - it's an $8 key (16GB). I just wanted to check before adding a USB cable to it.. (for ease of access).
