09 genesis 3.8 oil temperature sensor location
Genny215
Hey, I’m new here. And I just got a p0196 code for my genesis. But I can’t seem to find the oil temp sensor location. Does anyone know the location?
Any help would be appreciated, thanks
It is located in the inside the Automatic Transmission pan. I think you could be low on transmission fluid thus causing the high temp condition. READ the How to change transmission fluid Post to find proper procedures and insure correct fluid level.
You might remove the filling plug located just above the left front (drivers) side of the transmission fluid pan. You can add some trans fluid 1/2 quart or so but insure fluid level is correct.
Ok, thanks I was thinking it was on the engine somewhere. But ima check the trans fluid level too. This is the part
