100k Miles soon
lilxskull
Hi I am soon to hit 100k miles in the next year. I am currently at 90k. I have a 2009 4.6 Genesis
What do I need to do when I hit 100k. Is it just the spark plugs? Do I need to do the water pump also as I remember older cars used to do water pump and timing belt at 100k. Overall car has been great except for the electronics where my radio will go blank and say no signal but if I click FM it works again. And rear A/C does not work, but the heater does.
Check the owners manual for the maintenance schedule. If you don't have one, you can join www.myhyundai.com and download it in PDF format.
the 4.6 engine does not have a timing belt. I have put over 210,000 on my 2011 4.6 V8 and water pump is original, no problems. You need to have the transmission serviced and a new transmission pan/filter, cost about 700.00. Spark plugs yes and make sure you go back with oem laser iridium spark plugs(11.00 to 15.00 each plus labor) Re: rear AC -Check you rear temp control in console, it may broken. Other maintenance-Change brake fluid and radiator coolant. Change rear differential oil.
