2009 Genesis 3.8 Oil in the Electrical harness
lifeman
I have a 2009 Genesis 3.8 sedan. I've had 107,000 trouble free miles. Now my mechanic tells me that oil is coming from the engine, through the solenoid, and into the electrical harness. The "engine is doomed, but I don't know when" he says.
Is this in fact the signal that the engine will fail? Has anyone had this problem and had Hyundai review the situation? Would they do anything? Will replacement of the solenoid and electrical harness stall the failure?
everettclu@gmail.com
:welcome: to the forum.
This sounds like a useless mechanic with useless information. Here's a simple truth = all engines are doomed and will eventually fail. 1 mile... 1 million miles doesn't matter. We (people) are all doomed and we all die sooner or later too... later today or in 99 years. None of that tells us something we don't already know, nor can act upon.
Useful information would include: Identifying which solenoid. What part of the wiring harness. Why oil is leaking. Time and cost to correct the problem. The problem may indeed be something that would cost more than the car is worth to fix, but that is not evident from the information provided.
If you can get and share such details, then perhaps we can help.
Take a pic i can help u i had same problem
My used dealer sold a genesis, car returned to dealer check engine, same issues. Has damage been done to the PCM as I have read or can I clean out the oil and see if that's the issue . Oil leak was solved ,so hoping not to have to do a harness
