2010 Genesis 4.6 blowing hot air
Genny46PM
Santa Clarita, CA
I have a 2010 Genesis 4.6 with approximately 97,000 miles. It recently began blowing hot air from 2 driver side vents and freezing cold air from the passenger side 2 vents in auto and manual modes. I've followed all required maintenance schedule but AC was never an issue and there was no service to date on AC system. I haven't taken the vehicle to the dealer for diagnostics yet. Does anyone know what the cause is or has anyone had similar issue?
I recall seeing threads about this, and some fairly recently. It believe it is some kind of actuator that controls the vents that needs to be replaced. Do a search and see if you can find it.
Thank you for the reply. I found a few threads about the issue and it looks like the problem is the Drivers side Temperature control actuator.
So what’s the fix like I have an ‘09 started doing that not hot air but not as cold as the passenger or rear a/c
Anyone have a part number and where it is located? The driver temperature control module.
Thanks!
