2011 4.6 Key Fob issues
Rhino11950
I have replaced the batteries in both fobs, but no luck. They don't do anything (unlock doors or trunk) and I have to insert into dash to start the car. Any ideas?
Did they work anytime before you replaced the batteries?
can the fob batteries be put in backwards?
Does your nav screen and dome lights still work? I ask because twice now I had it where I had to insert the key to start the car, which was very odd since I have a new fob battery. The 2nd time I had an issue the car wouldn't even start! I went into the driver side door and opened the fuse panel and touched every fuse in the panel and when I hit the master fuse (the one with yellow plastic around the fuse) everything turned back on. Turns out somehow my fuse wiggles loose every few weeks, so I probably need to figure out why, or just replace the fuse.
