Hey Guys and Gals, I've got a 2012 3.8 with the 8-speed auto trans. It's got 113k miles on it and I've owned it for about a year (had 107k when I bought it).
I'm having some intermittent but noticeable transmission shifting weirdness. I'm getting occasional bad shifts from 2nd to 3rd and also 4th to 5th.
2 --> 3 : average disengagement of 2nd but grabs 3rd too early while revs are too high (typically only a could hundred RPM drop) and slams into gear. Not overly violent but more of a jerk than a typical shift.
4 --> 5 : slow disengagement of 4th, sits in neutral for around a second, revs climb while in neutral (sometimes as much as 2k RPM increase), slow engagement of 5th. Because of the slow disengagement and re-engagement of both gears I wouldn't call this a slam shift because there's never a big jerk, but power delivery is lost to the wheels for a couple seconds while all this is going on. Strange feeling.
I haven't been able to nail down a consistent set of conditions to reliably replicate the problem but I'd say in general this is happening more when the car is up to full operating temperature. But even then, it's not all the time.
I also did a scan of the computer with an OBD
scanner and did receive a code P0955 which comes back as auto shift manual mode circuit fault. However, I have no problems using the manual shift mode, it works fine (though the odd shifting does still happen sometimes in manual mode).
Anyway, I have limited experience troubleshooting automatic transmissions and any insight would be appreciated. Thanks!
P.S. I've purchased "Niteo Motor Medic M3616 Trans Medic Automatic Transmission Treatment & Shift Improver" from Amazon with the intention of adding it to the trans fluid. Figured this couldn't hurt, but please let me know if this is a bad idea. As far as I know the trans fluid has never been changed since Hyundai claims this never needs to be done.
