Donovan_787
- Mar 1, 2020
I have codes PO300, P0302, P0306. I was able to replace all of the spark plugs except cylinder #8. I was still getting the same codes. Initially I also had the code P0308, but somehow it went away even though I wasn’t able to get the plug out of cylinder #8 due to the high pressure fuel pump being in the way.
The car has 118,000 miles. What do you think is wrong with it? I decided to pour in Lucas injector cleaners in the gas tank and pray that it might be clogged injectors that is causing the misfiring of cylinder 2 & 6.
