Renniz
- Sep 19, 2017
- Location
- Tucson
I was ready to purchase a 2013 Genesis that was involved in a front end collision and has a salvaged/rebuilt title in Arizona.
I had it inspected and it is mechanically sound and structurally decent, but not perfect.
My concern is the airbag light. The seller replaced the one deployed airbag in the steering wheel, but not the airbag control module and I understand that none of the airbags are going to function right now.
If the steering wheel airbag deploys and then is replaced, can the existing airbag module be reprogrammed or does it have to be replaced and then reprogrammed by a Hyundai Dealer?
The local Hyundai dealer gave a quote for 2 hours to remove and replace the module and then another hour of labor for programming = $390 labor.
I believe the airbag control module for the steering wheel, part number is 959103M350 and is between $500 and $700.
There are used modules on eBay and there are places that can reprogram used modules, but a non dealer mechanic that I had inspect the vehicle informed me that I would have to buy a new module and only a dealer could reprogram it. They said a used module with a different vin would not work.
I understand that none of the airbags will function when the airbag light is on.
My concern is if I spend a thousand dollars that the system may still not be clear of errors and require more parts and labor.
One other solution that I thought of is to buy a new airbag control module and then send it out for reprogramming and then install it myself.
Any information would be greatly appreciated!
