2013 Genesis, Driver's power seat Sometimes won't move
Mark5020
Hello, people,
In a 2013 Hyundai Genesis sedan with a 3.8L V6 DOHC 24V engine,
the Driver's power seat Sometimes won't move (forward, back, up, down).
When pushing the Drivers Position Memory buttons on the door,
sometimes it works, sometimes not. It's an intermittent problem.
The levers on the side of the seat also Sometimes work, sometimes not.
That "Switch Assembly-Power Front Seat LH", Hyundai part # 88621-3M500
under the seat (the side controls) has been replaced, costing about $300.
What might be the problem?
Thanks, people.
Mark5020
Hello, people,
Thanks, people.
Mark5020
Check your wiring connections under the seat. Not just the plastic connectors but also the wiring metal "male/female" connectors in the plastic connections. I have had issues in the past with metal connections becoming dislodged from the plastic connectors causing faults.
There is something under driver seat on the left side where the seat slides back and forth that you can press to make it work again.
