2013 Genny Lighting
sparx2002
I upgraded my 2009 Genesis to a 2013 . I have no complaints with the car but when I open the door the dome lights don't illuminate right away the flicker a bit . Is this because they are LED bulbs or is this an electrical issue needing attention.
Electrical , check to see if it acts the same when opening each door.
It does it with all of the doors , definitely going in for service thanks for the reply.:)
check the master fuse surrounded by yellow in the drivers side fuse panel when you open the door on the side of the dash. I have the factory LED lights and mine flickered before and I checked this fuse and it was not seated properly. One I pushed it in, everything came back on and hasn't had an issue again.
