Leonard2611
- Nov 14, 2022
- Genesis Model Year
- 2013
So I have a 2013 3.8 ltr sedan. After changing the front brakes and rotors, the driver side now screeches metal on metal almost all the time when braking. I have checked the braking system twice and all is in good order. Only happens on the driver's side. On the underside of the spring clip for the brake pads, I did notice some contact marks. Is it possible that due to the design of the aftermarket spring clip which comes with new pads that under pressure of braking, that it is touching the outer edge of the rotor?? doesn't seem to happen when the car is on the lift and there is no weight on the suspension... Anyone else experiencing this problem
