2013 Sedan - front brakes screeching brake noise
Leonard2611
So I have a 2013 3.8 ltr sedan. After changing the front brakes and rotors, the driver side now screeches metal on metal almost all the time when braking. I have checked the braking system twice and all is in good order. Only happens on the driver's side. On the underside of the spring clip for the brake pads, I did notice some contact marks. Is it possible that due to the design of the aftermarket spring clip which comes with new pads that under pressure of braking, that it is touching the outer edge of the rotor?? doesn't seem to happen when the car is on the lift and there is no weight on the suspension... Anyone else experiencing this problem
I fear for your sake that it's not. Noise is bad. Loud grinding metal noise from brakes is very bad.
Make sure you don't have the pads (or clips) reversed, make sure shims are located on the correct pads. This is surprisingly easy to do on the 2007 Santa Fe's front brakes (ask me how I know). Make sure the wear indicator (screecher) is not bent out of position. Also check that you got the correct parts, and nothing is stuck between the caliper or dust guard and disc (little rocks will make a lot of noise too).
the first of all you need to check the caliper guide pin is stuck or not.
2, apply anti-squeel paste to brake caliper.
you can search youtube "caliper guide pin", "brake anti squeel paste"
