dan1239
- Nov 19, 2020
So, I got a correlation code for the crankshaft position sensor P0019 and the vehicle would take about 6 rotations of the starter before actually starting (long crank). I decided to replace the sensor and the car started up fine for about 4 start stop cycles. Moved the car off of the lift and it sat for a little. I tried starting it to leave and it did not want to start this time. It would crank and start really roughly then die immediately after. Took it to the dealership to get some answers and they had to contact Hyundai as they couldn’t even figure it out. Hyundai said that it could be a shorted ECU as there were no codes popping up. Any idea on what could be the issue? She only has 96k miles on the clock. No issues before this other than leaking valve cover gaskets and a leaking thermostat housing.
