2015 Genesis 5.0 Sedan Passenger seat dead
doubledown00
I usually leave the passenger seat all the way back. Over the weekend I moved it up some to give some back seat passengers more room. Later the seat wouldn't go back at all. I slid the switch forward and the seat went to its maximum then stopped. From there none of the other selectors work (no lumber, no recline, etc).
Things I have tried:
1) I checked the wiring harness on the back underside of the seat. Nothing was disconnected.
2) Using a Youtube tutorial I checked the back and forth relay on the right side with the little white nub sticking out.
3) In the fuse box I swapped the 30 amp jumper from the passenger side seat and the driver side.
I don't know if this is relevant but the seat cooling / heating still works.
What else can I try? Is this model known to have sudden power seat failures?
Mine did that too, there was a napkin laying under the seat...once I removed it the seat worked again, must be a sensor under there..
