I work for a genesis dealership. Just get the package that gives you 2 ecus. Old that has tune and your other that have original software. If anything happens just swap it out and they won’t be none the wiser about it.The BTR tune seem to make pretty good power(appears to be over 20whp). I did not know there was a tune for my 2015+ 5.0 engine, especially with the 3.3T around.
Alphaspeed Canned Tune ECU Service (2015-2016 Genesis Sedan
www.shopbtr.com
When my warranty expires I may give it a shot in my 2015 5.0.
Note: I notice on the BTR dyno test that the engine do not start making any power until about 2k rpms or higher like with the tune. The engine must have some type to failsafe that prevents WOT under 1.5k rpms; hence the laggy gas pedal from a standstill.
Good advice. That was the plan as well if I decided not to wait for my warranty to expire. I really did not want to permanently tune my main ecu anyway just in case something bad happens with the tune.I work for a genesis dealership. Just get the package that gives you 2 ecus. Old that has tune and your other that have original software. If anything happens just swap it out and they won’t be none the wiser about it.
Seems true that the stock pedal is restricted or regulated somehow. However, devices like the Sprint booster seem to overcome throttle restrictions. My throttle opens in the 90-100% range with my Sprint Booster based on my Torque Pro live logs.I either watched a video or read on another forum that full throttle these cars only go to like 80% open and that the gas pedal percentage vs the throttle open percentage is not a 1:1 ratio. I would have to think that a tune would take care of that though.
Yes. I have a TCU tune and stage 1.5 ECU for my DH from GEPTuned.Has there been any new news on this since 2021? Did anyone actually try any of these tunes for the ultimate model?
Are you happy with it? I've been debating on getting my 5.0 tuned.Yes. I have a TCU tune and stage 1.5 ECU for my DH from GEPTuned.
Go to gep tuned on you tube it shows what he can do and shows gains he gets on the dyno.Are you happy with it? I've been debating on getting my 5.0 tuned.
Yeah I've been happy with it. I had to send the ECU back and get it updated. I also removed the mild burble tune because it was causing me problems. Still highly recommend it though.I've watched his videos and even spoke with him via email. I'm just wondering if you are happy with it yourself? How does it drive after the tune? Does it get rid of that slight mid range hesitation at WOT?
What did you get updated on it, besides removing the burble?Yeah I've been happy with it. I had to send the ECU back and get it updated. I also removed the mild burble tune because it was causing me problems. Still highly recommend it though.
