2015 Genesis electrical issues
Thoneycutt
Second time this has happened within a month. Out of nowhere, I will try to start my car and it's completely dead. I was able to unlock it but when I sat down to start it I heard a little click then the steering wheel locks up,, break is stiff and no juice at all. The first time it happened it just came back on after an hour or so. What could this be? Thanks in advance.
Test your battery, or take the battery into a place for testing. My car had similar issues and I had a bad battery even though it was nearly new. A replacement battery solved this problem for me.
I'd start with checking the battery strength- if the battery in your vehicle hasn't been changed, it's right around the time the OEM battery would be ready to go on to that great battery heaven in the sky. I'd next check the battery terminals for looseness or corrosion. It sorta sounds like something is loose or shorting-out.
It was the battery. Thank you guys so much for your feedback,, I really appreciate it.
It may be more than just the battery. I replaced my battery today for the FIFTH time since November 2018. I also recently replaced the radio/navigation and menu screen because it was not turning off properly. This replacement did not eliminate the phantom drain on my battery.
This isn't uncommon. I purchased a Genesis 2 days ago, and took it back on the 2nd day. Car would shut off completely and then come on later. Dealership thought it was a dead battery. We knew better. Amazing car when it works, but.........
This is no help to you (sorry) but my car doe's the same thing, if you get any info please post, PS just had a scan ck no codes in system
Replace the visible link on the positive battery terminal. You can buy it online and its east to replace.
Thanks for your reply, I see two a 60 and a 100 which one did you change, Thanks again Rob
