drpearso
I have a 2015 V8 Genesis with less than 2,000 miles. When aggressively accelerating, the shift seems to stall then buck. It has happened between several gears. The dealer, working with Hyundai determined the problem to be a fuel line. After a complete fuel line replacement the problem did not go away and the dealer still has the car.
Has anyone had a similar problem? This seems like a transmission problem.
Thanks!
I had the exact same problem and they said it was the fuel line also. They changed the fuel line, and it fixed the problem, but now it is back again. It is very abrupt buck when shifting in the high RPM range. It is not a fuel issue, or if it is a fuel issue it may be due to the computer sensing high RPMs and shutting off fuel just for a slight second and then it is bucks, then drops RPMs. I think it is a transmission module ... let me read more. This needs to be fixed since my brothers 2015 5.0 is doing the same thing as mine --- he did not want to deal with it, so he traded his 2015 Genesis in on a 2014 Mercedes Benz. I need the Genesis seat with power side bolster for spinal/medical reasons. The Genesis is a great car, but I am starting to lose confidence in it .... just had to have a new battery put in it ..... assume due to FOB being to close to car and communicating with it???? Ummmm!!!!
