2017 Genesis G90 wiring Diagram to slice into factory amp harness to install aftermarket amp...i have a blue and a pink plug connector, not the 3 conn
ty3dixon
Genesis G90
wiring Diagram to slice into factory amp harness to install aftermarket amp...i have a blue and a pink plug connector, not the 3 connector one... any help??? Pictures...diagrams... tips.... anything would be greatly appreciated
Any luck?
I am looking for the same info to add a sub My lexicon amp is also two plugs, blue and red for a 2018 G90
I am responding to this with some information that may help. I searched around every where and couldn’t find an answer. I have a 2022 G90 premium 3.3T AWD (17 Lexicon).
I installed my Hifonics alpha 1500 watt amplifier and x2 Kicker VX 12’s. Car is sounding even more amazing.
On the driver side of the trunk, underneath the panels is where you can locate the stock amp. I pulled the RED harness and tapped into the RED and BLUE wires coming from it. They are right above on and other. For the signal wire I ran it to the in cabin fuse box and tapped into a “Module” slot. Once ACC power is on the amp turns on. Once you turn the car off, the amp turns off. I grounded my amp with the factory location on the right of the battery. Hope this helps someone.
Ya it does. Do we know If there is only one Chanel going into the sub as a svc from a stereo or a mono. Because if it’s a stereo two feeds in . Then your only getting a left or a right bass signal? Thanks
I am not specifically sure. I started taking out the back seat and removing the cover over the rear speakers because I wanted to see the connection but I gave up.
When I play with the speaker position in the infotainment system moving it from front to back doesn't change the volume of the sub.
When I play with the speaker position in the infotainment system moving it from front to back it does not change the volume of the sub.
