2018 G80 3.8 excessive oil consumption
lobewiper1
chicago
Hi All,
In the last 5000 miles, I've used 3 quarts of good
quality 5W 30 synthetic oil. I change oil every 5000 and prior to this, have only used about 1 qt. per 5000 miles. There are no signs of leakage in my garage, and the outside of my engine splash shield shows no signs of leakage. No visible leakage in engine compartment (3.8 liter engine). Ideas as to the problem appreciated!
Hi All,
How many miles on the engine? There could be different reasons if it has 35,000 vs 135,000 miles. Wear happens too.
Mileage is 85, 500, I'm original and senior owner and drive like a senior. The issue for me is the sudden and substantial increase in oil consumption during the past 6 months/5000 miles-70% city driving under 40 mph. Yes, wear occurs and has occurred, but why a sharp and recent increase? My driving habits haven't changed. Car is at dealer for oil change and examination. Will keep everyone posted and should get it back tomorrow.
It will most likely come down to a failed (clogged) PCV valve or carbon-ed stuck oil control rings.
joegr, thanks for your thoughts about this matter. My dealer doesn't think the PCV valve is likely to be the problem, and wants me to return after 1000 miles to see if oil consumption is still excessive. They are telling me that they won't do anything unless I'm using more than 1 quart per 1000 miles. As for using the Valvoline, that's not the oil they use and I want to keep having them do my oil changes to ensure they will honor the 10 year/100,000 mile powertrain warranty.
... As for using the Valvoline, that's not the oil they use and I want to keep having them do my oil changes to ensure they will honor the 10 year/100,000 mile powertrain warranty.
This is not to beat on this, I respect your decision. Be aware that the suggestion isn't to use that oil long term, only for a few changes to clean the rings off. They absolutely can't/won't void your warranty for using better oil.
OK joejr, I am going to try the Valvoline. I'm going to suction out all my old oil except that in the filter and see how things go. Will keep everyone posted.
Here is what the information will show. Both of these samples were taken on the same oil. One at 4,500 miles. The other at 6,600 miles. I was looking to understand if I should shorten my oil change intervals to 3,000 miles on my Twin Turbo - Supercharged G90. The results suggests that I should.
An interesting suggestion but a bit pricey. The cheapest option costs $65. Not sure it's worth it.
First step to solve a problem is to know what it is. The test will give more information than you will get posting on a forum. Alternative is to trade it in for a 2026 model.
EdP and Mdpresco, not sure I agree. I am following up with joejr's suggestion to try Valvoline Restore and Protect after I found some promising results on YouTube. I'm going to try it for a few thousand miles before doing anything else. Another option would be to conduct a compression test, although that involves removing the intake manifold. That is something I could do myself although it wouldn't be much fun. I'm reluctant to do the oil test you suggest because I would like this problem to be solved while the drive train is still under warranty. For that to happen, I need to follow the steps my dealer says need to be followed to obtain warranty service. Those steps do not involve oil analysis.
Happy Thanksgiving, everyone!
I have now put 1000 miles on my G80 3.8 since changing its oil to Valvoline R & P 5W-30. With the dealer's synthetic brand, I most recently used 3.0 quarts in 5000 miles, or about 0.6 quarts per 1000 miles. At this time, however, I can't see any change whatsoever on my dipstick, suggesting that I used a negligible amount over the 1000 miles since changing to Valvoline R & P. I'll post another usage update after 2500 miles on R & P. Thanks to joejr for suggesting that I try R & P! Happy New Year, everyone!
